![]() | Home > In Car Electronics > Rear view Camera |
Steve44 Member Since: 23 Dec 2013 Location: East Sussex Posts: 18 ![]() ![]() ![]() |
Has any one fitted on of these [url]http:// www.ebay.co.uk/itm/Veyron-VC-RRSP-Reversin...0943943668 [/url] 2009 RRS TDV6 2.7 HSE Santorini Black |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Fitted the same on a D3 , got the same one for £12.....ish
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Funnily enough I was looking on ebay yesterday for a new one,all the cheap ones seem to have disappeared. |
you need an interface peachy |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
The advert makes it look as though you may be able to plug & play |
It does say
aljo - any ideas for this :
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
does anyone know where i can get an interface from please as i too would like to fit a rear view camera |
Try http://www.hids4u.co.uk/ |
Peachy I now seem to remember that the rear camera was plug and play because the reversing lines on the screen were different when I plugged into the gvif unit the reversing guide lines were different again and Im sure there was an option in the interface only to remove the reversing lines , I dont have the D3 now and my memory is fooked due to old age (so the missus says) ![]() edit : Im sure its in the options using the remote |
mark.b I still have an gvif interface ,(removed from the D3) If you give me a couple of days to see what I did with it ![]() |
Hi Aljo that would be great if you could ill hold my breath and cross my fingers |
You need to go into the factory setting menu using the remote and disable the Park enable function " that should get rid of the lines ![]() |
Thanks Aljo i have fitted the unit and rear view camera cheers mate could you tell me where you connected the audio as the radio didn't have any av connectors on it so confused as to where i plug them in for audio |
