![]() | Home > Technical > Knackered caliper? |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Is it the disc pads binding or could it be brake shoe for parking brake maybe |
Dannutt Member Since: 06 Jan 2014 Location: Bucks Posts: 60 ![]() ![]() ![]() |
Disks looks a little blue so I'd be inclined to go with the AA dudes conclusion |
Anyone know where to get OEM replacement? What manufacturer or if new seals would be better? |
^^^ - Drop Steve (site sponsor) a PM, from threads I've seen on here, seems very competitive for all things |
I would just go for a complete stripdown and clean and check the disk for run-out caused by overheating as a first option as it costs nothing and usually solves the problem. The rear calipers are cheap and nasty single piston sliding pins type which have a propensity to partially seize.
So just unbolt and swing the caliper round, get some break cleaner and a tooth brush in around the piston?
Dannut - sorry that's one of the problems with forums; you don't know whether the OP is master mechanic or doesn't know one end of a screwdriver from the other |
