Home > Maintenance & Modifications > Servicing query.....
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hey guys.
Have read some great posts on here regarding servicing. It's all really great info and a heads up for me.
I've got an inbetweener I need some advice on.
I have an 07 RRS TDV6 that only has 47k on the clock.
By inbetween, I mean what servicing would you guys recommend?
Do I take more notice of my car being just 7 years old now or the mileage?
I'm reading about cam belt, oil pump casing replacement, pulley guides as a precaution and such like.
This is the best motor I've ever owned and want to look after it as I plan to own it for a while.
Does anyone recommend a transmission oil change too?
I bought from a main dealer nearly 12 months ago.
I may as well get any work done with the MOT.
Many many thanks,
Gaz, Bristol.
Post #409911 Fri Jan 17 2014 5:37pm
mse
Its age or miles, so miles will trump age if you do sa 20k a year, you will be doing a 40k service in year 2.
But if your car is 7 years old, you will need to do the yr 7 service at year 7 regardless of miles.
If you want to look after it, a car never complained of having new oil...the most simple and best thing you can do for anything (as long as its not weekly on low miles!) Mike
2014 Facelift Discovery
Post #409917 Fri Jan 17 2014 5:47pm
Gaz
Thanks Mike.
Where can the information be found on what's advised as a car ages?
Is it a simple case of looking in the manuals?
Post #409933 Fri Jan 17 2014 6:55pm
drdelrrs
Look in owners section of LR website.
Post #409939 Fri Jan 17 2014 7:20pm
Gaz
Post #409941 Fri Jan 17 2014 7:25pm
mse
Actually the service schedule (the one you actually need) is on here somewhere....do a search Mike
Post #410008 Sat Jan 18 2014 10:01am
mse
http://www.rrsport.co.uk/gallery/albums/us...0UK-EU.pdf Mike
Post #410010 Sat Jan 18 2014 10:03am
Gaz
Thankyou so much Mike!!
I'm going to print this off and highlight what I think I will need doing.
I bought from a main dealer almost coming up to a year ago now. They did say that it had a service and was looked at.
When I picked it up, even though on an 07, it only had 35k on it. I have about 46k now.
I have budgeted £1000 for around the 50k mark to ensure that anything that could cause a catastrophic failure is dealt with. (not sure if 50k is too soon).
Hopefully it'll satnd me in good stead for a few more years then.
Gaz.
Post #410019 Sat Jan 18 2014 11:34am
mse
You are probably looking at a B service with a few extras.
Do you know a good independent LR person - you might be better off there Mike
Post #410028 Sat Jan 18 2014 1:02pm
Gaz
I have a regular busy garage I have used for years and trust 100%.
I will try and get a price from an Indy in Bristol.
I have got in touch with my main dealer to ask if they have any recorded service history they can furnish me.
(Should of asked when I bought it I guess!!...lol)
Do you think 7 years or 50k is too soon for a front and back cam belt change?
Post #410036 Sat Jan 18 2014 2:57pm
mse
You can never really change a cam belt too early in my opinion (well within reason). The more you don't know the history, the more you give yourself some piece of mind.
the only reason I suggested an independent was for cost and likelihood to do some preventative stuff in a way a dealer might not Mike
Post #410038 Sat Jan 18 2014 3:02pm
Gaz
Thanks so much for the continued advice mate. Thumbs Up
Gaz.
Post #410040 Sat Jan 18 2014 3:04pm
mse
No problem Mike
Post #410041 Sat Jan 18 2014 3:06pm
