Home > General (L494) > Headlights set too high
Widdle
Anyone else getting flashed repeatedly by oncoming traffic assuming you've got your headlights on main beam? Mine seem to be set quite high. Is there an easy way to adjust them or is it a return to dealer job?
Post #409963 Fri Jan 17 2014 8:50pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Mine are too high aswell, at first I though they were no where near as good on main beam as the old HST, then when I drove under trees, could see the main spots shining way to high, not got brave enough to turn the adjuster screws myself and not worth a trip to dealer just for that... 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #409978 Fri Jan 17 2014 9:41pm
JimR
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
The first time I drove mine in the dark, the car in front kept flashing its hazard warning and fog lamps at me. A few seconds of main beam put a stop to that.
I have Xenons so that are self-levelling. I think the issue was that the lights are so high off the ground that when following a lesser vehicle at a slower speed the lights can shine straight at the leading car's rear view mirror even when they are dipped. ---------------------------
MY13 HSE Black Edition
Santorini Black with Black Interior
It's Very Black
Post #409998 Sat Jan 18 2014 6:34am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I must admit I do not think that the headlights are as good as the ones on the RRS MY12 that I traded in.......
Post #409999 Sat Jan 18 2014 6:38am
JimR
I traded in an Audi Q5 for my RRS. The Audi also had Xenons, but the lighting on the RRS is far superior to the Audi.
I never realised how much I disliked that Audi until I got the Sport. Very Happy ---------------------------
It's Very Black
Post #410000 Sat Jan 18 2014 6:40am
malcolmw
I have also had people flash me when on dipped beam but when you look at the cut off in pitch darkness with the vehicle on level ground it seems reasonably OK.
I put it down to a combination of the high mounting of the lights, the tip up/down of the air suspension and the self levelling headlamps themselves interacting to keep the dip cut off too high for too long. I'm not sure that adjusting will help. Also the sideways splash of the lamps on dip is quite bad (non-adaptive lights). Just look at the inside of the car coming the other way as it passes.
I agree about main beam. Mine are set high and slightly leftwards. Not worth taking in specially to adjust though. Regards
Malcolm
Post #410024 Sat Jan 18 2014 12:09pm
Widdle
Feel sorry for oncoming drivers, I can't stand it getting dazzled. Might have to dish out sunglasses to other drivers...
Post #410042 Sat Jan 18 2014 3:07pm
JimR
OOOPS.......................just realised this thread was aimed at the rich people in the MY14s Sorry Embarassed ---------------------------
It's Very Black
Post #410044 Sat Jan 18 2014 3:30pm
Widdle
Don't worry, we're all broke after buying them! Very Happy
Post #410118 Sat Jan 18 2014 10:14pm
SDV6RRS
Ditto to the OP. I keep getting flashed and I have the impression that they are set to high. A tweak downwards might improve things, but as someone else mentioned I thought that they were self levelling, although they don't go though the dance that the X5 did when you turn them on.
As much as I love the new RRS the headlights are not a patch on my old X5. The range that they used to give on full beam was astonishing.
I'm heading to France in a few days and am still amazed that "the beam pattern does not need adjusting for driving on the other side of the road". (Yes, I know HBA needs doing though). We shall see how many times I get flashed... 2014 MY RRS HSE Dynamic
2000 Porsche Boxster S
2004 BMW X5 (Gone)
Post #410136 Sun Jan 19 2014 9:21am
Dickie
I got back a week or so ago having driven to Switzerland and can report that pretty much every other oncoming driver flashes furiously!!
The beam pattern most certainly dazzles traffic to the left which is completely at odds with what the manual says. Not much I could do whilst there but all I'd say is be prepared for several irate oncoming cars…. or just drive in the day!
Post #410416 Mon Jan 20 2014 10:02pm
Aintree
United Kingdom 2013 Range Rover Sport SDV6 HSE Aintree Green
Mine were also set far too high - main beam lighting the tops of trees, embarrassing passing dazzled cars on the motorway, being 'given the finger' by one and flashed at continuously by oncoming traffic.
Resolved by a visit to Hunters in Kings Lynn. No more flashing, should have been a quick pitstop but 3 software updates required, took 2 hours Shocked
V poor for the factory to send out new cars in this state, hatred for these vehicles is already enough without the dazzling headlights. Do they set them with the suspension in access mode?
P.S. No auto levelling evident on mine (non adaptive)
Post #412682 Wed Feb 05 2014 7:00pm
malcolmw
@Aintree,
When did you take delivery of your car? I wonder if I should take mine (4th December) in for the update.
I also can't see any evidence of auto levelling but it may be highly damped (which causes this problem). Regards
Malcolm
Post #412752 Thu Feb 06 2014 8:16am
Aintree
@malcolmw
Mine was delivered end of sep, with any luck yours came more up to date!
Post #412783 Thu Feb 06 2014 10:24am
Dickie
What were the updates?! Mine was delivered mid October and not noticed any issues - apart from the high headlights when on continent. Sounds like I might need to speak to dealer if there's software updates required as I assume unless they're mandatory safety ones they won;t recall the car.
Post #412899 Thu Feb 06 2014 7:37pm
