![]() | Home > Technical > Noise from front end at 25-30 MPH...hub? wheel bearing? |
Sounds very much like a wheel bearing from your description, jack the front end up and see if there is any play in the front wheels, try rocking the wheel by holding the top and bottom of the tyre, see if there is any movement. If there is, then its your wheel bearing that needs replacing. |
USAFBuckeye Member Since: 24 Feb 2013 Location: Il Posts: 60 ![]() ![]() ![]() |
Ady,
rjc001 Member Since: 21 May 2010 Location: Houston, TX Posts: 15 ![]() ![]() ![]() |
Hi
RJC,
You were all correct. It was the right front hub assembly.
Thanks for the update, pleased you got it solved and repaired under warranty |
