![]() | Home > Technical > parking sensors |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
How do you know the rear ones are fine ?? 16MY Estoril Blue SVR.............
Do you still get the bleep? one long continuous bleep ? with the error message ? Front parking aid inactive ? common fault - the sensors don't last forever - if you get the bleep - it's a sensor. Ideally you need a diagnostic tool to read the codes this can identify the offending sensor location. Mine used to dry out therefore work & then stop when it rained causing intermittent problems.
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Are they turned on ??? I believe they can be turned off on the dash, check the button MY16 AUTOBIOGRAPHY Indus silver with some toys
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 ![]() ![]() |
the rear ons bleep as they should when you get closer to a fixed item one continuos tone but the from are dead nothing i have checked to see if the wife had turned them off at the dash switch and no she hadn't looks like a trip to the steelers to get diagnostic checked |
So there's not even a message on the IP |
no peachy no message at all mate |
Have a quick look at this may give a little help |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 ![]() ![]() ![]() |
Mark
