Home > Maintenance & Modifications > RRS keeps pulling to the left slightly |
Drive at 70mph. |
Wed Jan 15 2014 3:16pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Cant stop the pulling though if I did |
Wed Jan 15 2014 3:33pm |
Try swapping your wheels around, front to back. |
Wed Jan 15 2014 3:36pm |
Hi Ady
Wed Jan 15 2014 3:52pm |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 |
Try jacking the front up and see if the front wheels spin freely I'm thinking you may have a brake lightly binding |
Wed Jan 15 2014 9:28pm |
Thanks mark will give it a bash on the weekend.
Wed Jan 15 2014 9:37pm |
Or another way to check that, see if that wheel is hot after a run.
Thu Jan 16 2014 7:30am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
I know that you have had the 4 wheel alignment done, but, binding brakes aside, this really is the most likely cause. It may well be that the rear wheels are parallel with each other, but not with the chassis. This would cause the car to "pull" and you will wear tyres unevenly because the steering is being held slightly in lock to compensate.
Thu Jan 16 2014 9:13am |
