Home > Faults & Fixes > Front sitting lower in access mode
LOCUST
Hi
ive had an issue when when parked in normal mode the front drops to access mode height when the engine is off..
ITs been looked at and no air leaks apparently at the front end., but 2 red lines when I start up in access mode at the front.
So I had it re calibrated, and now the rear seems to be sitting more higher in access mode than before.
does it drop to the bump stops ?
if so I don't see how its possible for the back to sit higher in access mode ?
Whats my next thing to check ?
there is a noticeable 50mm difference between the arch and tyre between front and rear
thanks
Post #409299 Mon Jan 13 2014 11:01am
Paddi
Height sensors at the front.
Front valve block.
If you are handy with the spanners changing height sensors is simple and if you search the site for 'valve block' you should find a post where a DIY hero put up a 'how to' on dismantling, cleaning and reassembling the front valve block to fix it.
Could you firstly though get the fault codes read with a decent diagnostic tool that understands LR specific DTCs? 2008 MY Java Black TDV8 HSE
Post #409381 Mon Jan 13 2014 8:10pm
