Home > General (L494) > Park Assit
dfy123
Park Assit
Hi There
Has any one had a problems with there park assist, used it today for the first time following all commands as instructed and also the comment remembered on the away days says trust the car, I did and guess what done a lot of damage to my front passenger alloy, totally gutted will be contacting L/R tomorrow?
Post #409220 Sun Jan 12 2014 4:50pm
JimR
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Does the MY14 come with more than the front and rear sensors?
If not, then I don't think that you will get much sympathy from Land Rover. There are notices all over the place that tell you that it is designed to assist you when parking but that you should still use mirrors etc when maneuvering.
I had to wait at a service desk in a JLR dealers once whilst the receptionist explained to a very irrate Jaguar owner that the rear assist was there only as an aid and that Jaguar were in no way responsible because he had reversed into a post his rear sensors failed to detect. ---------------------------
MY13 HSE Black Edition
Santorini Black with Black Interior
It's Very Black
Post #409221 Sun Jan 12 2014 5:25pm
JimR
Apologies dfy123, Embarassed
I've just done some research on the LR website and discovered that the new Parallel Park Assist actually parks the car for you. In which case I would definitely take it up with LR.
Good luck and let us now how you get on. ---------------------------
It's Very Black
Post #409222 Sun Jan 12 2014 5:39pm
dfy123
Thanks for your time and your comments
Post #409223 Sun Jan 12 2014 6:13pm
lodaka
I've been using the park assist without too much problem. One of the times I felt that it was going to hit the card behind me so I stopped it -- in hindsight, I was probably ok but didn't want to take any chances.
I am curious to learn more about how it damaged your front passenger rim. If anything, I would expect the rear passenger rim to be damaged on the curb (or even front or rear bumpers).
Post #409554 Tue Jan 14 2014 10:54pm
Mark_N
Dfy123, what size alloys do you have? I'm afraid that the larger alloys are especially prone to damage not only when parking but when attempting anything off road. It's easy to think of a wheel being scuffed when it slides into a rut. I've managed to scuff a couple of my Evoque wheels doing exactly that and they are only 20 inches. To be honest, a car with the RRS's off road credentials and 22 inch rims are not comfortable together.
I think the Park Assist function is a potential nightmare for LR because of the possibility of claims for damage in such a wide variety of parking situations which is why they will say ultimate responsibility rests with the driver. My guess is they will offer a wheel refurb if it's minor (£100 - £150) or a new rim (£700 - £1200). In the litigious US, I would have thought it a legal minefield but the parallel parking is much less common than it is here.
By the way, do you have surround cameras and, if so, do they take priority over the reversing camera when you engage reverse or does the reverse camera only image take priority? In the Evoque, you cannot use the surround cameras in reverse for this reason which makes it a pointless option.
Edit: Looking at your other posts, I can see you have optional black alloys. I feel your pain! Going to be expensive for someone. Mark
SVR in Estoril Blue Thumbs Up
Post #409574 Wed Jan 15 2014 6:29am
Mark_N
What did LR or the dealer say when you showed them your damaged rim? Mark
Post #412737 Thu Feb 06 2014 7:25am
dfy123
Well they had the car in for 5 days loads of wiring tests backwards and forwards to L/R eventually they recommended replacing the park assist module, guess what on back order waiting for part to arrive, the replacement alloy has arrived and will be fitted when the park assist is fixed, we shall see.
Post #414067 Fri Feb 14 2014 8:35pm
trez63
United States
Glad to hear they've owned up to it
Post #414265 Sun Feb 16 2014 9:12am
Mark_N
Yes, good they are replacing the rim... Mark
Post #414312 Sun Feb 16 2014 6:21pm
