![]() | Home > Technical > Front parking sensor aid inactive on dashboard |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Welcome to the Forum - do you still get the bleep? one long continuous bleep ? with the error message ? .Common fault - the sensors don't last forever - if you get the bleep - it's a sensor. Ideally you need a diagnostic tool to read the recent error codes this can identify the offending sensor location. Mine used to dry out therefore work & then stop when it rained |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 ![]() ![]() ![]() |
Hi peachy
Chechen fuse 36, 5 amp fuse parking sensors it was good? Do the control module have separate fuses? |
Try this |
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 ![]() ![]() ![]() |
Peachy is the best!! |
fredouille Member Since: 05 Jun 2011 Location: BORDEAUX Posts: 13 ![]() ![]() ![]() |
hello,
Thanks very much, just need to find the part number now? |
LR006482 |
rumz Member Since: 06 Nov 2014 Location: Horley, Surrey Posts: 101 ![]() ![]() ![]() |
Hi All,
Anyone? |
A damaged/corroded loom would not be unlikely. |
Thanks mate,
