![]() | Home > Maintenance & Modifications > Air Suspension Renewal |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
If you change the entire strut, air spring and shock should make a difference, but only if you have replaced worn upper and lower arms. Doing them yourself can be a bit of fun, should cost around £800. |
Leon1551 Member Since: 06 Jan 2014 Location: Cardiff Posts: 1 ![]() ![]() ![]() |
I have a 2007 RRS and for a while the wobbly vehicle orange warning sign has been on, about 2/3months ago a warning came up normal height only "suspension fault" but I was able to adjust suspension manually. Last week while driving home the warning has now started flashing and I cannot adjust suspension manually or remove the warning off the dashboard.
hello your issue may be an internal leak on your compressor, caused by a weak exhaust valve. My rrs started by intermittantly flashing up amber with the suspension fault. I fixed mine 2 years ago and not had any issues. Its also is worth checking the wiring in the front wheel arch. Just requires a few upgrades to the compressor, also it would be worth drying out the air dryer at the same time. The TSB below explains how to upgrade the compressor.
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
compressors we can do to forum members for £450inc vat delivered Sophie Alltoft
