Home > Maintenance & Modifications > Puddle Light problem
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Since I got my Sport the puddle lights on the bottom of all four doors haven't lit when the door is opened. It never really bothered me until I decided to change my interior bulbs to LED’S after reading a few threads on the forum here. I just always assumed the bulbs must have went and hadn't been replaced. When I removed the old bulb on every door and stuck the new LED bulb in it lit no problem on each door....fine I thought, I must have been correct in my assumption, the old lights hadn't been replaced when blown.
I moved on to the boot light which had always worked ok and removed that, and replaced with new LED, new LED came on when inserted.....job done i thought. Locked up the car. Came out an hour later to run a few errands and.....No puddle lights come on and no boot light!...Don't have a clue what is wrong any ideas anyone? Searched through the search function but can find nothing pertaining to this particular problem. Any help greatly appreciated. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #408257 Sun Jan 05 2014 8:57pm
Idea Have you tried opening the passanger door? Might be drivers door light switch that is faulty. Confused
Post #408259 Sun Jan 05 2014 9:14pm
mad-dafty
Tried all four doors Ady, none of the puddle lights on them work.....but all did when i first inserted the new led's....then when I tried them all later, none worked and my boot light didn't light either....strange. Confused 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408274 Sun Jan 05 2014 10:34pm
Paul Holywood
Have you checked the fuse?
Post #408277 Sun Jan 05 2014 10:44pm
mad-dafty
Never checked the fuse Paul....do you know what fuse it is and where the fuses are located? Embarassed 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408281 Sun Jan 05 2014 11:26pm
Try the lower glove box, once open you have to pull the inner edges of the glove box in towards each other then lower the box further. The fuses will be behind there. If in doubt refer to hand book to find the fuse number. Thumbs Up
Post #408319 Mon Jan 06 2014 12:42pm
mad-dafty
Strangest thing Ady...wife was out in the car last night, when she came home reported that the puddle lights still were not coming on. I drove the car this morning and low and behold the puddle lights came on...tried all four doors and all came on.ok.....crazy. Shocked 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408321 Mon Jan 06 2014 12:45pm
Laughing Spooky...
Post #408322 Mon Jan 06 2014 12:46pm
