Home > Technical > 2.7 TD V6 7 Year Service information required
C11RRJ
England 2007 Range Rover Sport TDV6 HSE Java Black
Hello everyone. This is my first post on here although I joined a few month back when I purchased a MY07 HSE 2.7TD.
My car was running great until last month. I have had the Compressor, Alternator and one EGR valve replaced in the last month under my LR Select warranty.
Its coming up to the 7yr service (41k miles) and I have got my local Indy doing the job. I have sourced all genuine parts and all I require is the 2 x idler pulleys for the front timing belt. Would you advise genuine pulleys or OEM?
This site has been so helpful so thanks to all people on here!!
Post #407948 Fri Jan 03 2014 5:10pm
Disco_Mikey
The idler pulleys from Advanced Factors are OEM, and a fraction of the price of a main dealer Thumbs Up
On EU4 engines, I would advise having the oil pump casing changed for the revised, stronger version. Well documented weak point on 07/08MY's Thumbs Up
Post #407975 Fri Jan 03 2014 8:03pm
Isn't genuine and oem the same thing Question
Post #407976 Fri Jan 03 2014 8:15pm
Stuart
The former comes in a very expensive box Ade. Rolling with laughter
Post #407982 Fri Jan 03 2014 8:41pm
Disco_Mikey
Genuine comes in an LR branded box
OEM is exactly the same part, in a non-LR box Thumbs Up
Post #408006 Fri Jan 03 2014 10:06pm
C11RRJ
Thanks for the replies!
Post #408059 Sat Jan 04 2014 11:17am
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
In a word... yes Very Happy MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's
Post #408061 Sat Jan 04 2014 11:22am
C11RRJ
How do I know which aux drive belt to purchase. ACE or non ACE? My chassis starts off 7A. I'm tending it think it has ACE? PQS500420....
Post #408201 Sun Jan 05 2014 3:45pm
Disco_Mikey
PQS500370 is non-ARC
If you have a reservoir attached to the air filter box, then you have ARC Thumbs Up
Providing they have not been retro-fitted, if you have front Brembo's, then you will have ARC
Post #408206 Sun Jan 05 2014 4:27pm
C11RRJ
I have located the reservoir and I have brembos on as standard! Thanks for the swift reply!
Post #408217 Sun Jan 05 2014 5:21pm
