Home > Maintenance & Modifications > Oil for Range Rover Sport HSE SDV6 |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1831 |
You can use Shell Helix Diesel Ultra AF-L 5W-30 2023 P440e SE Dynamic on order -cancelled
Tue Dec 31 2013 5:11pm |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 |
I also use Shell Helix Diesel Ultra AF-L 5W-30.
Tue Dec 31 2013 7:12pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
Thanks for the advice not sure what oil landrover put in from the factory does anyone know? Also is it advisable to do an early first oil change on a RRS.
Wed Jan 01 2014 1:33pm |
I think it is Castrol Professional or something like that. You cannot buy it unless you are in the trade I believe.
Wed Jan 01 2014 1:44pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Miller oils do the correct spec one. Bought mine via Opie Oils when on offer |
Wed Jan 01 2014 2:21pm |
You are right it is this one, XF LONGLIFE C1 5w30 :- http://www.millersoils.co.uk/automotive/td...sector=Car
Wed Jan 01 2014 3:18pm |
Mike767 Member Since: 31 Aug 2012 Location: Cheshire Posts: 19 |
I have a 3.0 TDV6 HSE (2011). The oil spec is WSS M2C 934 B as the car has a DPF fitted. I'm not sure what spec the SDV6 requires, but if you need the same oil, Carlube Triple R 5W 30 C1 is available. I got mine delivered from Euro Car Parts for under £40 for 10 litres. |
Tue Jan 07 2014 9:10pm |
