Home > General (L494) > Snow chains
Ilron
Snow chains
Is there anybody on here that have checked the distance between the wheels/tires and the suspension joints?
I would like to know if there is clearance enough for _proper_ snow chains on the new model.
LR messed up that detail on the D4, considdering this is a new chassis I hope there is plenty of room...
Post #407096 Mon Dec 23 2013 10:03pm
Disco
You can specify the traction devises for the rear wheels for up to the 22 inch wheels. Do they fit really, not sure.
Post #407100 Mon Dec 23 2013 11:23pm
Ilron
Thanks, I have not tried the so called traction devices, but I guess they are worth looking in to as an alternative.
Post #407102 Mon Dec 23 2013 11:33pm
SVR575
Range rover recommend the Spike Spiders i believe and i think they should be put on the front axle. SVR 2018 in Santorini Black.
Post #407163 Tue Dec 24 2013 9:22pm
SDV6RRS
Not for the 2014MY. They say rear axle only.
Have to say, if you were to fit snow chains, surely the front axle is better - steering and braking come high on my priority list... 2014 MY RRS HSE Dynamic
2000 Porsche Boxster S
2004 BMW X5 (Gone)
Post #407195 Wed Dec 25 2013 2:33pm
mse
There are many different types of chains that attach in a number of ways, a fair few don't hook round the back...but LR will recommend the set that takes into account clearance. Mike
2014 Facelift Discovery
Post #407198 Wed Dec 25 2013 5:25pm
Tboner
Similar issue was told a NO on the fronts . spoke to someone i know who works on tech at the factory was told the only way was to fit 20" slightly narrower rims and tyres to run front snow devices / chains, otherwise rear only ! poor design IMO, Problem is with a 4WD is getting going is not the problem it's stopping them and getting round corners.
So 20" with proper winter snow tyres is the way for me Vred wintrac ext's etc. 2014 5.0SC AB
Gone 5.0 SC
Post #407200 Wed Dec 25 2013 8:34pm
Quote:
the only way was to fit the 20" slightly narrower rims and tyres to run front snow devices / chains, otherwise rear only ! poor design IMO
How is it a poor design? The RRS was designed to accommodate up to 20 inch rims with a certain tyre size. If someone fits something larger than that then it's not LR's fault if stuff no longer fits. Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #407212 Thu Dec 26 2013 8:06am
Tboner
aburgh ! A standard RRS wheel and tyre will not take chains on its front end ? ! Rolling Eyes Rolling Eyes Rolling Eyes
and the 2014 Car takes up to 22" Rims not up to 20" 2014 5.0SC AB
Gone 5.0 SC
Post #407215 Thu Dec 26 2013 9:13am
Disco
So the correct chains/devises on the rears and when needed snow socks on the front.
Post #407217 Thu Dec 26 2013 9:35am
mse
Actually the 2014 sport comes with 22 as standard...I think that's the point.
but then, same token as the last sport - 19" was the better size for off road etc, the 20" less good.
THe land rover chain system (made by RUDD) is a good system (but a pain) because it only clamps on the front, using the bolts for the wheel and a plate - you then clip the chains to that. Rather than the cheap chains which you wrap the wheel in and damage the alloy
Snow Socks and chains do very different things - ignoring socks aren't legally a replacement for chains in Europe - there are conditions where the socks just wont work and you need chains.
If you have chains on the rear I wouldn't bother with socks on the front... Mike
Post #407218 Thu Dec 26 2013 9:41am
Tboner
Thought the 20" or 21" were the STD rims may be wrong and 22" are a pay for option.
but not to be able to fit the normal chains on a standard RRS 20" rim ?
The JLR LR005737 is the RRS, Disco , Freelander2 and RR traction system that fits up to a 20" rim from memory 2014 5.0SC AB
Gone 5.0 SC
Post #407220 Thu Dec 26 2013 9:52am
Disco
http://www.snowchainshop.co.uk/autosock-snowsocks
Have a read. They are classed as an alternative.
Yes I agree they do a diff job to actual chains, but if are desperate for something on the fronts then it appears a sock could be the only option, if they come in the right size.
Size of wheels.
The 22 inch wheel is an option in the uk. So 19/20 and 21 are the std sizes.
Post #407221 Thu Dec 26 2013 9:53am
Ah, yes, in that case it is a rather odd decision on LR's part. But then they seem to have made odd decisions in lots of areas in the last few years of product development.
Maybe they've come to the conclusion that people in the UK who want to use chains are so rare that they didn't bother designing for them and just gave them the big shiny wheel choices they crave. A bit like the decision to drop the low range transfer box because people don't go off road.
When most LR products live in towns and spend their lives on big shiny rims coated in summer rubber you can rather see their point... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #407222 Thu Dec 26 2013 9:57am
Tboner
19" will not fit a 2013 on car , will not clear the brakes as far as i am aware,
Just been into workshop and yes the Disco 3/4 snow stuff is that part number.
I still think good snow tyres are the best option but you can really only get in 20" at the current time which is the better option giving more tyre wall flex and more grip.
pain in butt is if you happen to drive to the alps for example there are many resorts that will not let you up there past the road patrols unless you have all 4 wheels chained up or studded tyres, Ok that is likely to be very few people from the UK but if you are in the EU and fancy a quick weekend in val etc it's a real pain in butt. 2014 5.0SC AB
Gone 5.0 SC
Post #407223 Thu Dec 26 2013 10:10am
