![]() | Home > Technical > Fault Code Reader |
You'll only get basic engine management fault codes fo that generic type of tool. Bodsys Brake Bible
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Bodsy you actually might be wrong here
stevemfr Site Sponsor Member Since: 21 Aug 2011 Location: Strasbourg Posts: 55 ![]() ![]() |
The Chinese Mongoose knock-off alone will not do you much good - you still need IDS or SDD (OEM LR diagnostic SW) to make it work. And in my experience, using Chinese knock-offs and illegally copied SW is anything but plug n play - though it can be fun if you have time and patience |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
I bought an Autel Maxiscan MS509 for about £28. Yes it only covers engine management faults, but it has saved my nephew money twice when I read the faults & re-set his management light. The MS509 can log faults and can be downloaded to a PC or laptop.
