Home > Orders (L494) > Roof Rails?
Mark_N
Roof Rails?
I bought roof rails for my Evoque simply because I think it improves the looks (not difficult, you Evoque-haters will say) but I've never actually used them to carry anything.
Any thoughts about them on the RRS? Mark
SVR in Estoril Blue Thumbs Up
Post #406967 Sun Dec 22 2013 9:42am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I have used them for carrying my bike , to move timber and to carry a roof box.
All removed when not needed Thumbs Up
Post #406969 Sun Dec 22 2013 11:07am
Simon C
Any tips for getting the cross bars on the rails? I think I am being a bit dim!!!
Post #406982 Sun Dec 22 2013 2:09pm
whippetman
Yes, does need a little lateral thinking!
Start in the middle,slot one end in then walk around to the other side and push pull the bar till it fits,then you should be able to jiggle the bars to where there are slots further down.
I use a bit of silicon spray from the DIY store in the track,better than WD because there is no residue.
To remove slide bars back to centre.....
There is a lot of jiggling involved and takes less time if there are two of you doing it Whistle
Post #406989 Sun Dec 22 2013 2:58pm
Simon C
Yes it turned out to be a difficult experience! In the end I opened the sun roof, stood on the front seats and did it from the middle. The feet are certainly not very user friendly!
The next issue is that my Xtender ski rack will not extend because there is a slight bow in the bars (both of them so I assume this is a design issue and not damage!) which means they are not completely striaght! I guess I will have to pack them when I get to Chatel, can't do it now because it will cause a whistling.
You would have thought that this should be quite a simple job! At least the snow chains (XXL K Sumitts) went on easily enough, but if I have to use them I think I will throw the car back to Landrover!!!! Big Cry
Post #407040 Mon Dec 23 2013 10:50am
whippetman
Are your cross bars LR originals?
Post #407051 Mon Dec 23 2013 12:59pm
Simon C
Yes. I have Thule Whisper bars that I can't use because there are no feet yet (that I can find anyway) for them, so I shelled out for LR bars.
What have you got?
Post #407053 Mon Dec 23 2013 1:03pm
whippetman
I went from the Thule set up to the non-LR original rails and bars off fleabay.
Big mistake, look the same as LR but quality is not good.
Just as well I don't need to use them too often.
Post #407056 Mon Dec 23 2013 1:17pm
Simon C
Understand!
At 85-90mph with 4 pairs of skis for 600 miles, I want as good as I can get!!!! Cool
Post #407057 Mon Dec 23 2013 1:28pm
CBL1
What have you got?
Simon - this would indicate (for an older RRS anyway) that the bars CAN be fitted directly into the guttering on the car without the need for LR rails?
http://www.roofbox.co.uk/fitting/whispbar/PRK436.pdf Maserati MC Stradale 2016
RRS 2017 SDV8 AutoBiography - June 2018
RRS 2010 Supercharged - 2013-May 2018
TVR Tuscan Mk1 3.6li - 50k miles and counting
2000 Mustang GT Convertible 4.6li V8 - Gone and much missed
Post #421262 Mon Apr 14 2014 8:23am
Simon C
Well, I don't know I am afraid, I had an X5 for the Whisper bar and a D4 before that on which I used JLR bar and feet.
I guess if you have the correct feet feet the whisper bar will work as the bar itself is universal. I don't know about the rail, but if it is the same as the D4 there is a track in the gutter that fits the foot for the bar.
Post #421271 Mon Apr 14 2014 10:53am
