Home > Faults & Fixes > vibration
austencameron
vibration
I have a vibration through the whole car from 60mph and up, had wheels balanced and changed wheels and tyres and still there.
any help would be appreciated
austen
Post #407023 Sun Dec 22 2013 11:09pm
doldy
What model, year and wheels do you have?
Post #407024 Sun Dec 22 2013 11:16pm
austencameron
tdv8 2007 with standard 20" rims
Post #407035 Mon Dec 23 2013 8:23am
BKHK
Can be anything from tyres, wheels, discs, steering rack or rear diff. Lots of troubleshooting to do. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #407048 Mon Dec 23 2013 12:06pm
drdelrrs
Centre prop-shaft bearing/support.
Post #407058 Mon Dec 23 2013 1:39pm
Paddi
^^ +1
Or could be front propshaft CV joints or rear propshaft front/rear UJs. 2008 MY Java Black TDV8 HSE
Post #407060 Mon Dec 23 2013 2:45pm
jetbags
Re: vibration
austen
Yep me too.... Can this be a coincidence that suddenly these cars are demonstrating the same characteristic fault ? I have heard of several other members having this same fault over the last month with no real outcome or fix.
In my case, this is just one of a long line of sudden faults that have sprung up in the last couple of weeks. It started with the HDC fault showing at startup, this has now progressed to "SUSPENSION Failure" now also showing which denies the option to raise or lower the car.
Having asked a question recently, a member stated it could be the battery draining which then tells the cars brain to restrict certain items, effectively the non essentials ????? So I will be getting the battery checked straight after Christmas to see if this is part of the problem. I have recently had a Blackvue camera installed with the power saver so am wondering if this extra continuous load onthe battery has had a detrimental effect on the electrical system.
Any advice / experience of the points above would be grately accepted I really need to get the vibration issue sorted as it's a worry when driving at 70mph to have such imbalance on what is normally a silky smooth ride. 2005 Rang Rover Supercharged
Loving every minute !
Post #407070 Mon Dec 23 2013 7:15pm
BKHK
Jetbsgs, it's not the car restricting certain functions, it's that they are very sensitive to under voltage and a dying battery or alternator is often the first fix for spurious and multiple warnings. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #407076 Mon Dec 23 2013 8:48pm
jetbags
Having not had a vehicle before that is as "sensitive" as a Range Rover, it's becoming a real test of my patience. My previous car was a superb Lexus 300 sport which in three years never once caused me a second of trouble. The Land Rover however has been a real eye opener of just how poor a luxury car can be !!!
It's off to get this battery checked first then, thanks for the heads up what is a very tricky problem..... 2005 Rang Rover Supercharged
Post #407098 Mon Dec 23 2013 10:25pm
