Home > Technical > Another stepper blend door motor problem.
sheefo2k
United States 2007 Range Rover Sport 4.4 V8 HSE Siberian Silver
Hello all
I am in the process of figuring out what is wrong with my RRS. I have a 2007 RRS US LHD none-SC.
My entire left driver side blows only cold air and in any zone. The passenger side blows warm air in any zone as it should. I did my research on 3 different RR and Disco forums and I know the culprit had to be either the entire HVAC unit or the left blend step door motor is not functioning correctly. I removed the motor and the white plastic moved a long when I turned the dial. I was also able to manually turn the flap door it self but with no luck since I still have cold air in both settings.
How can I eliminate if there is something broken or if there is something stuck in the door? I have removed my entire arm rest, center console, NAV, Radio, heater controls and most of the dash. I am also making a DIY and will post it here once I complete the job.
Any information will help.
Post #406311 Mon Dec 16 2013 3:28am
sheefo2k
Any update?
Post #406481 Tue Dec 17 2013 4:17pm
muddywheels
Milk Float Man
Might be worth asking on Disco as they appear a bit more hands on than here Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #406482 Tue Dec 17 2013 4:19pm
sheefo2k
Fair enough, I will give them a shot.
I tried two other forums and no luck. Maybe third time is the charm.
Post #406483 Tue Dec 17 2013 4:27pm
muddywheels
Milk Float Man
You could pm http://www.rrsport.co.uk/forum/member-disco_mikey.html or http://www.rrsport.co.uk/forum/member-bodsy.html they are very knowledgeable Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #406484 Tue Dec 17 2013 4:33pm
sheefo2k
I am getting some responses on the Disco forum but I will take your advise and pm the following members.
Thanks, Cheers.
Post #406500 Tue Dec 17 2013 5:16pm
Disco_Mikey
IF you have it plugged in to a diagnostic machine, it will give a specific fault code for a blend motor.
You can check the live readings, and see if the HVAC unit is trying to command the motor, and what position the motor is at Thumbs Up
Post #406536 Tue Dec 17 2013 10:22pm
sheefo2k
I do not have a diagnostic machine. I have one for my l322 but it won't work for the sport. :/ Confused Confused
So what could it be? The motor turns with the dial and I can manually turn the gear but it doesn't fix the problem. Does that mean I have to replace the entire heater core?
Post #406562 Wed Dec 18 2013 2:05am
Disco_Mikey
It could be a weak motor, not strong enough to move the flap Thumbs Up
As I said, having it plugged in would reveal all
Post #406564 Wed Dec 18 2013 7:42am
sheefo2k
Fair enough, which tool do you recommend for the occasional home user who is contemplating selling the RR? Laughing
Price is also a factor.
Thanks
Post #406565 Wed Dec 18 2013 8:10am
Disco_Mikey
If you are not keeping the car, its cheaper to take it to a garage and let them read the codes.
Otherwise, the IID Bluetooth gets my vote Thumbs Up
Post #406588 Wed Dec 18 2013 11:09am
