Home > General > PLEEEEEASE HELP RRS SUDDEN DEATH!
simple1
I would bet alternator. Wet cell battery's will regenerate to some degree if run flat, possibly enough to work dash lights etc but unlikely to start the car. Sounds a bit like a dead short that resolved itself. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #406368 Mon Dec 16 2013 5:44pm
theforman
United Kingdom 2005 Range Rover Sport TDV6 HSE Adriatic Blue
Bodsy wrote:
That would only stop it from starting, you would still get ign lights and hazards would always work.
My money is also on an alternator and if you believe that it will fix itself, it won't, only next time it will also fry your battery.
The elements inside an alternator can work intermittently and unless you have a really poor earth or battery connections, alternator is the only way to go.
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
well ive got a big grin from ear to ear right now, im so glad everyone took there time to give me so many reply and this site is a great thing to all landrover owners,,
just to give you all update sofar,, i took the sport out last night for a run to the shop and back and lights were almost candle power, so today i borrowed a multi tester and yeessss guess what ?? the battery was showing 11.2 volts even with heated seats on lights on, with the engine running there was no voltage rise even with wifey holding revs to 2ooo rpm, so im going to change alternator next few days myself and save some wedge,
happy days
ill get back with the results
the forman
Post #406375 Mon Dec 16 2013 7:34pm
theforman
Bow down whats the easiest way to replace an alternator on a rrs tdv6
Post #406376 Mon Dec 16 2013 7:45pm
mse
The easiest way - get someone else to do it Exclamation Mike
2014 Facelift Discovery
Post #406378 Mon Dec 16 2013 8:07pm
DrLex
Iceland
It won't be too different to these instructions for a D3.
There has been some discussion about whether non-OEM alternators are up to the job- your call.
Post #406380 Mon Dec 16 2013 8:17pm
flack
Just the same as a D3 should take about 35 mins if the fan comes off, Unless the car has ARC fitted then its a bit longer...
Flack Thumbs Up
Post #406381 Mon Dec 16 2013 8:35pm
Judging by the number of L/R alternator failures you have to ask yourself are they upto the job Question Especially on the TDV8's Whistle
Good luck changing it though Thumbs Up
Post #406382 Mon Dec 16 2013 8:40pm
theforman
cheers for that, i couldnt beleive how easy it was to get at and get off,, get a newone tomoz,
regards the forman Thumbs Up
Post #406552 Tue Dec 17 2013 10:12pm
theforman
Update,,,,
Alternator changed and no more faults //// touch wood,
Regulator had gone in alternator,
Kind regards to all that took part in my problem,
Post #409224 Sun Jan 12 2014 5:31pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Good news! Thanks for update . Thumbs Up
Post #409226 Sun Jan 12 2014 6:00pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Good news. And good on you for tying up the thread- so much more useful when searching through when you have the same issue.
Post #409227 Sun Jan 12 2014 6:18pm
