Home > Technical > Suspension adjustement bolts
mixerman
Just fitted front lower arms and track rod ends so im off for a 4 wheel alignment check. As I had to cut off both rear bolts at the front , what are the rear adjuster bolts like for seizing up is it likely they will be seized too ? Thanks.
Post #406166 Sat Dec 14 2013 7:19pm
Disco_Mikey
Rear track rods can be tight, but a little heat frees them off again no bother Thumbs Up
Same with the rear upper camber bolts. Seize inside the bush, but can still be turned Thumbs Up
Post #406171 Sat Dec 14 2013 7:34pm
mixerman
Ok thanks
Post #406222 Sun Dec 15 2013 10:45am
