![]() | Home > Wheels & Tyres > Brembo Brakes and 19inch wheels |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Mate 19" fit with no issue - no need to remove anything, I'm running the same combo |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
As C10KO said, you should not need to remove the weight, wheels will fit ok.
vnitos Member Since: 03 Nov 2010 Location: pretoria Posts: 32 ![]() ![]() |
@flydive, which 18" wheels are / did you use? |
Compomotive PD1880
Stephen J Member Since: 28 Oct 2013 Location: Amsterdam Posts: 16 ![]() ![]() ![]() |
I just read that Compomotive went out of beeswax. Any info on that? |
They are still trading. PD1880 still available.
Thanks for that! |
