Home > Maintenance & Modifications > gearbox filter range rover sport tdv6 2006 |
One of our wonderful mods might want to move this to the right section.
Wed Dec 11 2013 12:42pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
I did it on my TDV8 which is similar.
Wed Dec 11 2013 1:18pm |
Cbroadrr Member Since: 10 Nov 2013 Location: Middlesbrough Posts: 5 |
iv bought the replacement part from land rover so it has suction pipe on and cant get the new one in as subframe in the way |
Wed Dec 11 2013 1:34pm |
Well, then you have to release the right engine mount and jack the engine up to get clear access.
Wed Dec 11 2013 1:36pm |
The official Land Rover way of doing it says remove the transmission support crossmember. There is a pdf version of the Disco 3 manual on this link (first item on the list) and you need Section 502-02.
Wed Dec 11 2013 2:13pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Undo RH engine mount, transmission crossmember, and jack the whole.lot up as high as it will go.
Wed Dec 11 2013 3:08pm |
