Home > Maintenance & Modifications > Heated rear screen fixed (again!)
Paddi
Almost a year after I had to fix my rear screen heater I've just had to once again clean the connections under the rear spoiler. This time I sealed up the block where the wires enter it with some black Granville sealant as this seems to be where water is getting in and causing corrosion.
If you have a 2005 - 2009 model with a non-functioning rear screen heater this thread may help you sort it out: http://www.rrsport.co.uk/forum/topic29082.html 2008 MY Java Black TDV8 HSE
Post #405313 Sun Dec 08 2013 1:52pm
