Home > Maintenance & Modifications > Paddle shift activation in ccf
aljo
paddle shift activation on my rrs 2010 which is MY2011 with MSV2
I have enabled in the ccf for paddle shift and works ok but a P0700 fault code come up straight away
(Transmission control system (malfunction indicator lamp request)Is there a correct procedure the enable this function ! Any ides what will have caused this ? and will it be safe to drive like this or would it be better to disable again(car not being used for a week or so)
thanks Thumbs Up
Post #404882 Wed Dec 04 2013 10:04pm
aljo
bump Thumbs Up
Post #404997 Thu Dec 05 2013 5:49pm
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
paddle ccf
that is were i enabled mine without a problem ,have you tried deleting the fault to see if it will come back .
Post #405275 Sun Dec 08 2013 12:22am
aljo
hi merlin
yes ive cleared P0700 fault but comes back straight away
enabled the paddle steering wheel function in the ccf but no option availible in the EUCD
the paddle shift works fine through all the gears with no problems
when first enabled it had engine management light showing on dash screen but cleared when fault codes cleared
fault code is stored in ccf and wont clear
no warning lights now showing and paddles work in both the command shift and normal drive
is it possible that maybe another not so obvious function needs enabling in the EUCD
Post #405295 Sun Dec 08 2013 10:33am
