![]() | Home > General (L494) > Alternative cycle carrier options |
ikeysolomon Member Since: 02 Jul 2007 Location: High Wycombe Posts: 60 ![]() ![]() ![]() |
Neil,
naubin Member Since: 13 May 2013 Location: UK Posts: 4 ![]() ![]() |
Thanks - and I appreciate when moving a lot of bikes around then this is a no brainer...
I'm with ikeysolomon, I looked at various options when I got my RRS and the tow bar was the best. On my RRS replacement (BMW 5 series) I even specced the electric tow bar (£880) just for my bike rack. Well worth it IMO. |
Widdle Member Since: 27 May 2005 Location: Petersfield West Sussex Posts: 70 ![]() ![]() |
I had roof bars and two Thule bike racks on my X5 roof and putting them on was a doddle. Did hit mpg though. If only once every two weeks you could keep the rack in the garage and put it on only when you need it. Takes five mins. You'd need to spec roof rails to attach it though. |
hornbaek Member Since: 11 Dec 2013 Location: Richmond Posts: 39 ![]() ![]() ![]() |
Im using SeaSuckers that simply attach to the glass panorama roof with suction pads. Works great and is cheap and easy to remove.
ROB9772 Member Since: 31 Dec 2013 Location: MK Posts: 15 ![]() ![]() ![]() |
I personally wouldn't hang a rear door mounted carrier on the back of any decent car. They swing around and bounce and there is a good chance of scratching your paintwork as well as making opening the back impossible. I use a roof system but it's not easy lifting bikes on top so I could only recommend the tow bar option. I wish someone would come up with a cheaper tow bar solution, manufacturers are taking the mick with them ! |
There are cheap tow bar solutions out there, but as with most things in life, you pay for the quality (LR prioducts excluded of course |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I wouldn't use that suction system, it might pull the glass out going over a big bump in the road. As Beano says, you get what you pay for. Not much point driving an RRS if you can't afford a decent bike rack. A damaged RRS and a damaged bike are not a good look. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
jisaacs Member Since: 05 Jul 2014 Location: London Posts: 19 ![]() ![]() ![]() |
Hi Neil
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
that's quite weird!!!
meeting him tomorrow for pick up - Thank you so much!
