Home > Maintenance & Modifications > Front axle noise
Ridgebacks
Front axle noise
My front axle is making a grumbling noise worse at 20-30 mph Big Cry Where / how do I check the oil level before I try out my warranty 2016 SVR
Post #404308 Sat Nov 30 2013 8:31am
Bodsy
Site Sponsor
There's no axle, but there is a diff.
Usually that noise is a front wheel bearing. Jack it up and check for up down movement on the wheel. Or grinding when you spin It (don't forget to be in neutral and chock the rear wheels) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #404310 Sat Nov 30 2013 8:40am
Ridgebacks
Many thanks I did mean the diff but will check the wheel bearings tomo Thumbs Up 2016 SVR
Post #404312 Sat Nov 30 2013 8:56am
Ridgebacks
Drivers side wheel has play,new wheel bearings will be fitted soon Big Cry 2016 SVR
Post #404429 Sun Dec 01 2013 2:33pm
Ridgebacks
I can confirm it was a wheel bearing fault many thanks bodsy Bow down 2016 SVR
Post #404879 Wed Dec 04 2013 9:26pm
