Home > Technical > RR Sport Dynamic Control Module and Brake Faults
amirmughal
Kenya 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Hi, Need some advise on my DTC's being experienced since I did a major service on my Sport 06. Replaced most of the service items like Timing Belt, High Pressure Belt, Alternator, Starter, waterpump and Thermostat housing, Gearbox Oil Filter and Fresh Oil in Transmission.
The car started well and ran many kilometres before I decided to attach a Launch X431 Pro to it. Was shocked to see many errors come up, including a F in the dash display! The most persistent errors that are not clearing up are:
U0122 - lost communication with Dynamics Control Module
C1A00 - Control Module permanent error
Park Brake Fault -
HDC Fault - system not available
I dont see any errors on the System Check while starting car and also it runs well. These erros only appear when connecting a scanner. I tried also the ortiginal SDD software and it showed same errors.
What is the Dynamics Control Module and how can this error be rectified. Seems an electrcial issue ? We had removed many cabkle and sockets during the above service procedures ... not sure if this could be a casue or my DCM needs replacement?
Please assist as I spend many weeks doing major work on my car and am disappointed now on these faults not going away, even after sveeral resets.
Many thanks,
AM Amir Mughal
RRS 2006, Zambezi Silver, HSE, FACE LIFT 2012
Post #404249 Fri Nov 29 2013 7:31pm
