Home > General > Drivers heated seat module location
deanodf
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi can Anyone help
I am trying to fine the drivers seat heater module, i have had the seat up as far as it goes and looked under with torch but could not see it ????
I haven't got any heat in this seat and was going to try and swap it with the rear seat which work fine and is easily located underneath.
Thanks
Post #403795 Tue Nov 26 2013 8:21pm
Paddi
The seat heat is provided by heating elements in the form of a mat incorporated under the seat covers. The heating elements can fail and can be replaced but you will probably need to employ a trim specialist to make a neat job of it.
There is no seat heating 'module' so I don't know what you have found under the rear seats. 2008 MY Java Black TDV8 HSE
Post #404064 Thu Nov 28 2013 12:19pm
