![]() | Home > Technical > Engine aux heater + timed climate |
Yeah, timed park heater has been an option, but in reality, the aux heater is ther (unless a dealer can confirm it's not!) but the timed parking heater is an option.
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Thanks for the info Bodsy...I've asked the dealer to check with LR to see if these are pre fitted but not enabled. I'll have a look around in the morning too see if I can spot one! On the old RRS the webasto was at the front passenger side...but on cursory inspection it doesn't look as this is the same on this model. |
Well as far as I can deduce reference timed climate and remote climate for the new RRS plus auxiliary heater, as has been standard on D3/D4 Discos and the prior RRS here is my supposition:
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
On the 2010/ 2013 RRS the FBH was fitted as standard, And worked when engine was started,to assist in warming up engine quicker.It could also be pre timed by on screen timer settings. Dealers said they were unable to set up the Remote system,and was offered as an optional extra from new at £1025. The hardware to do this, Remote pliper,reciever,and Aerial can be purchased for as little as £157. So they were looking for around £868 to impliment some software. Little wonder they have earned the name Stealers itisme |
There is a difference between the feature of timed climate and remote park heat and the unit that can be made to deliver those features.
