![]() | Home > General (L494) > Disappearing TFT |
Cooperman Member Since: 02 Nov 2013 Location: Uk Posts: 75 ![]() ![]() |
UPDATE:
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
Pardon my ignorance mate(newbie here) but what is the TFT? |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
TFT (thin film transistor) is the technology used to implement laptop and iPad screens. In these models of the RRS, the instrument panel is actually a PC type screen with the instruments appearing as graphics. Not only that but when you go off-road, the screen is reconfigured; the speedo goes off to one side to make space for the axle articulation schematics. Mark
Thanks Mark for a clear and concise description. Now i know. |
SteveK Member Since: 15 Nov 2013 Location: Bucks Posts: 21 ![]() ![]() |
Had the same problem driving to work this morning. TFT screen has quick flash of horizontal lines then blanked out for a couple of seconds. Then reloaded and all was fine.
Luminated Member Since: 13 Oct 2013 Location: County Amtrim Posts: 27 ![]() ![]() |
I've had similar problems on an Audi A6 with the pop out screen, it would occasionally switch off closing the screen to then moments later pop back out and work again as if nothing have happened. I reckon there's just to much tech in cars now a days and occasionally they cause problems with one another. |
G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154 ![]() ![]() |
It's curious if each time happens at the same point; all electronics on board supposed to be blind from electromagnetic fields, but it could be a possibility.... This kind of problems is why I don't like to buy recently development cars.... ![]() ![]() (ARS) XE1UN 13 RANGE ROVER SPORT HSE SDV6 Orkney Grey/Black (Spain) 07 RANGE ROVER SPORT HSE TDV8 JavaBlack/Black (SOLD) 05 DISCOVERY 3 G4 V8 (Spain) 02 DEFENDER 90 BLACK LE TD5 (SOLD) 13 FREELANDER 2 (LR2) HSE Lux SI4 Havana/Black (Mexico) |
peter350 Member Since: 15 Oct 2010 Location: Preston Posts: 1 ![]() ![]() |
cooperman did you get this fixed? I've experienced it about 5 times in 1900 miles now. Thanks Peter |
chris_J_G Member Since: 12 Apr 2007 Location: Bristol Posts: 23 ![]() ![]() ![]() |
I had this a number of times on our FFRR, it had a few software updates but this didn't cure it, went in to the dealers about 2 weeks ago and they changed the complete binnacle, so far so good. so it may also be a hardware issue... MY07 TDV8 HSE (BAS Remap), Java, Privacy Glass,Tasmods. |
Binnacle changed. Didn't fix it. But then, bizarrely it behaved itself for a few months until recently when it has gone haywire again. Haven't time to spend my life at the dealer, so living with it for now.
