Home > General > 2010 RRS not unlocking and locking with key fob
intense33
Hi all,
I hope someone can help. My key fob is not allowing me to lock or unlock the car. It was working fine, no low battery message on the dashboard... I have had the key in the ignition for the 6 mins required to sync with the car, but still nothing. This doesn't happen in just one location, i.e. it happens at work, home, petrol stations etc.
I have tried to re-sync the fob pressing the unlock and lock button solution... this doesn't work either.
I have a spare key which has never been used, i cant seem to get any charge into this key, i cant turn the car on with the spare key (I can turn the ignition but the car wont fire up) i have tried the sync solution above but this does nothing either. If it is fully dead does it need a new bat?
Any help would be greatly received.
Chris
Post #403570 Mon Nov 25 2013 1:02pm
The G Man
Wales 2012 Range Rover Sport SDV6 Autobiography Baltic Blue
Hi Chris, I recently had an issue with only one key working in my 2012 RRS, not sure if it is the same system as yours. Changed the battery in the fob but still no joy. The stealers tried all sorts, tried to reset it and then tried to re programme a new key but eventually they diagnosed a problem with the key locking system 'brain' which wouldn't recognise the other key. They changed the brain(and made a pigs ear of the trim) but now both keys work as they should. Hope that helps. Good Luck.
Post #403603 Mon Nov 25 2013 7:25pm
intense33
Thanks Martin, I best get down to my local RR specialist. I really hoped it would've been easier, I've already had the door latch changed. Nightmare car at the moment...
Thanks again
Chris
Post #403641 Mon Nov 25 2013 10:30pm
