![]() | Home > General > Cruise control |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
Could be the brake switch - it has an initial switch that disengages the cruise control and then the next position activates the brake lights. Might be worth having a look at it. 2012 SDV6 - it's missing a couple of cylinders
Agree with RRSTDV8 try the switch.
OldBoy Member Since: 25 Nov 2013 Location: Somerset Posts: 4 ![]() ![]() ![]() |
Thanks, I'll certainly check it out. Just seems random - sometimes going over a hard bump, sometimes for no reason at all. |
Any idea where the brake switch is located? |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Above the brake |
The forum's excellent search facility (using +brake +switch as search terms) brought this up as the second entry on the results list:
Have a look at this thread too.
