![]() | Home > In Car Electronics > I got a gvif to fit by I'm confused now. |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
Dosent take much to confuse me. |
Thanks mate
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
If you are going the DVD route, you can buy a 6 changer cheap enough to go in the right rear pod (with a little mod or two) but why not consider something like storing your films on an i-something or other and just plugging straight into the GVIF input
Thanks for the reply.
As I expect your GVIF is going under the passenger seat I would suggest wiring a set of the aux/RCA cables up to a socket at the rear of the centre consul if you have something there already or adding whatever suitable connector to whatever apple sell in terms of cables (sorry don't know that first hand). I have seen cables wired all the way up to the glovebox along with power so you can leave your device in there. Paul Redding
Ah cool.
We'll I fitted the gvif and dvbt today. Managed to get a brilliant picture but no sound.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Try putting an Aux connector in the aux hole on the back of the cubby box - it just needs the jack inserted |
Thanks for you reply mate but I wanted it with no wires in view. |
I have the small end of the Aux lead left in the connection hole - it is discreet & does the job well - if there is a way - I'd be interested to see it - the freeview Tv was fitted by a different technician & he couldn't find another way |
I was thinking of getting a phono to 3.5mm jack cable cut the jack end off and route it under the centre console and piggy back it onto the wires going to the aux port?
Let us know how you get on |
