![]() | Home > Technical > Alternator or Battery? |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
With the multimeter over the battery terminals, start the car put on dipped beam and give a little acceleration (1500rpm) the reading should be 14.0V - 14.6V there abouts.
Jaggy,
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
Classic symptoms of alternator failure,
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
Hi
jaggy Member Since: 09 Jun 2012 Location: Kent Posts: 8 ![]() ![]() ![]() |
Hi Guys
I welded a couple of 10mm ring spanners together, so they fitted on 2 of the bolts. Then put a tube over it so i could hold the pulley in position while i got a pair of stiltsons with a tube on them. The fan came off quite easy then. |
