Home > General > Cat D |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
It depends on what type of car it is. 2014 L405 SDV8 RR Autobiography
Sat Nov 23 2013 11:07pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
rough guide 25-35% |
Sat Nov 23 2013 11:40pm |
buster11 Member Since: 15 Jan 2010 Location: Brighton Posts: 32 |
The main thing to endeavour to establish is - what was the damage and do they have photos to prove it
Sun Nov 24 2013 12:35am |
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 |
Tbh If i was spending for e.g 20k on a rrs I would never buy a cat D car, instead of getting a cheaper cat D i would spend that little bit extra in getting the same spec but being 100% sure about it, I simply wouldnt take the risk.
Sun Nov 24 2013 1:07am |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
Glass's guide online free valuations have a tab to allow for damaged vehicles.
Sun Nov 24 2013 7:08am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Car d implies the car has been damaged but not structure where as C is deemed beyond economical repair and suffered structural damage. CatD requires a VOSA VIC check to obtain log book (vehicle identity check £45 at VOSA centre) where Cat D doesn't but category will appear on log book.
Sun Nov 24 2013 9:26am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Ask to see any photos of the damaged car.....then make you mind up. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Nov 24 2013 9:31am |
other problem is when you look at cat d cars damaged for sale some are minor, some are pretty bad, its not so much of an issue on a cheap old car but if a cat d is still a 20k car then it must have had alot of damage for a company to write it off istead of repair, when as a 2k car could get written off for a minor scrap, also be very carefull its a bump and not a flood/ fire damged car as they will be an electrical nightmare! The cat C vosa check is also not to identify stuctural repairs its simply to make sure its not a ringer. |
Sun Nov 24 2013 11:53am |
as Shadrack says
Sun Nov 24 2013 6:34pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
If you have to ask yourself these questions.
Mon Nov 25 2013 7:19am |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
And even if you decide it's an acceptable risk- when you come to sell it on potential buyers will ask exactly the same questions. Most will just not bother and buy one that isn't cat D and save the hassle.
Mon Nov 25 2013 7:57am |
