![]() | Home > Technical > Car is going crazy is it a Battery issue !! |
Almost all systems communicate through the instrument cluster/assembly and if the battery voltage is low this will cause the 'Christmas tree' effect with the warning lights.
jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15 ![]() ![]() |
Iv just replaced it with new battery so why would I need to charge battery
Iv just seen on net that I may need to take it to Landrover to get re coded what's your thoughts ? |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 ![]() ![]() ![]() |
If it was all fine before replacing steering wheel, have you put it back together properly? What was the reason for replacing steering wheel? 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
Yes tried replacing it with old one makes no difference ! Replaced it because I got new one from Kahn |
Nothing needs recoding, are you sure the new battery is fully charged, unless the wiring is wrong just changing the wheel should not cause any problems.. try a hard reset and see if that fixes it, and also what is the alternator pumping ot volts wise..
Hi flack
Flack what's hard reset ? Taking battery leads off tap them together and then re attach ? |
Yes thats it, but if you are getting that error code about bcm it has some how corrupted something, I think you might need to sync the ipack with the bcm to get rid of the error. The only thing I can think of is the battery was low when you reconnected it and this caused your problem.
Cheers flack I'll take it to Landrover and see what they say |
Ferrar Member Since: 17 Nov 2013 Location: Salisbury Posts: 2 ![]() ![]() ![]() |
Hi Jonny
