Home > Faults & Fixes > Arb bushes & suspension fault
A3hyo
England 2008 Range Rover Sport TDV8 HSE Java Black
Ordered new arb bushes & clamps from duckworths and am going to get them fitted this week. Hopefully that should be the end of the knocking noises and creaking over bumps.
Today though suspension warning light came on and said " normal ride height only" I plugged it straight into diagnostic machine and following code came up
"Pressure increases too slow when filling reservoir"
From searching on here it would seem my compressor needs changing, where is it located (thinking it might be worth doing it same time as bushes)and what are the best options as I have seen a similar post on here about a company called Landyair who recon compressors and I think they are based just round the corner from me.
Post #402578 Sun Nov 17 2013 8:59pm
PEACHY
Located underneath - passenger side just in front of the rear wheel it's inside a black plastic casing. Is it noisy ?? 16MY Estoril Blue SVR.............
Post #402579 Sun Nov 17 2013 9:03pm
A3hyo
I never thought is was noisy until today. I was sat in car with diagnostic plugged in and as soon as I cleared the fault code the compressor fired back up and did sound a bit noisy, but not sure if it was just more noticeable as I was listening for it with no radio on etc.. It then came up with same fault approx 4 minutes later so I didn't clear it again.
Post #402581 Sun Nov 17 2013 9:08pm
PEACHY
It can be a DIY job but there is a newer version now - AMK - Flack or Bodsy ( site sponsors ) can give a bit more advice. They have been known to be refurbed - I replaced mine - sweet as a nut & very quiet. They usually last 40 - 60k miles. A sure sign they are failing is a noisy compressor. Give Bodsy or Flack a pm. Thumbs Up good luck. 16MY Estoril Blue SVR.............
Post #402583 Sun Nov 17 2013 9:15pm
