Home > Faults & Fixes > Weird question
07RRSTDV8
Weird question
As you can see from the photos my manifold is now being done.
My mechanic noticed that at the back
It has a "body shock absorber" either side.
But my front has th brackets but no shock absorbers?! Is it supposed to have these?
Post #402079 Thu Nov 14 2013 3:54pm
07RRSTDV8
Don't know where my photos went?
Post #402083 Thu Nov 14 2013 4:01pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
that's weird. Mr. Green
Post #402087 Thu Nov 14 2013 4:21pm
muddywheels
Milk Float Man
Do you mean these in your gallery Confused
This one needs rotating Whistle
 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #402096 Thu Nov 14 2013 5:15pm
Paddi
Scary pictures Shocked
I'm surprised your mechanic isn't familiar with Technical Service Bulletin LTB00241 though.
This is the one on fixing knocking from the suspension when driving over poorly maintained roads. In an attempt to stop the noise being transferred through to the body Land Rover engineers recommended removing the front body dampers and then bolting massive (12.8 kgs) lumps of pig iron to the chassis carrier (mass dampers).
Good luck, hope it all goes back together nicely. 2008 MY Java Black TDV8 HSE
Post #402097 Thu Nov 14 2013 5:27pm
07RRSTDV8
Yep there the pics! Thumbs Up it was chirping and squeaking as I accelerated. It's the drivers side front port as a slight 3mm gap between manifold and block hopefully going to linish the manifold flat again.
Ok I'll let him know, thanks for that.
Post #402101 Thu Nov 14 2013 6:13pm
Stephen J
Netherlands 2005 Range Rover Sport Supercharged Java Black
Sad
Post #402143 Thu Nov 14 2013 10:06pm
07RRSTDV8
Some more photos!
Had to raise the engine out as some of the manifold studs have snapped.
EDIT: how the h*** do I add the pics to the post?
Post #403206 Fri Nov 22 2013 12:27pm
Go to your gallery, click on an image, the select the BB code for the image
BBCode off Wink
[img]http://www.rrsport.co.uk/gallery/albums/userpics/18633/normal_image~5.jpg[/img] ON THE WAY: BMW F21 M140i
Post #403207 Fri Nov 22 2013 12:33pm
BBCode on Thumbs Up
Post #403208 Fri Nov 22 2013 12:33pm
PaulHH
Scotland 2006 Range Rover Sport Supercharged Stornoway Grey
Its amazing to see a body come off like that, did everything go back on easily enough? hope it did Thumbs Up 2006 Supercharged
Post #405187 Sat Dec 07 2013 9:51am
