![]() | Home > General > heater remote |
It only activates time climate - but only when the temperature is cold enough and if the system is ready to be activate (eg it doesn't need a purge)
Mitch1710 Member Since: 19 Aug 2013 Location: Co Durham Posts: 29 ![]() ![]() ![]() |
What do you mean by the time climate working from the screen mse ? |
Timed climate is the system. The remote only activates it without you getting in the car or it running the pre-programming.
On there touch screen where you choose radio, nav etc. it's should be on there should it ?
that's it, main - root - menu under timed climate
No, it's not there, strange when it came with the remote I ll ring the dealer tomorrow and find out.
Just to be sure |
Cheers for the photo's no I haven't got that on my menu but the remote is the same |
Im 99.9% sure if you don't have the menu, you don't have timed climate so your remote is a paper weight.
Yes that goes without saying I thought Mike
