Home > General > Drivers side of car - Soaked. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Will do - Thanks Mike 16MY Estoril Blue SVR............. 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
Sun Nov 03 2013 10:34pm |
just made the message make a bit more sense Mike
Sun Nov 03 2013 11:17pm |
Update - changed the tailgate rubber - checked the front drain holes on the sunroof - they are draining ok - the back drain holes are not does anybody have any idea how they travel through the car ?
Sun Nov 10 2013 4:20pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
The back ones are behind the D pillar and travel down through to the bottom of the car, you nee to remove the D pillars to gain access to them.
Sun Nov 10 2013 5:04pm |
Thanks flack - the interior D Pillar trim ? do you know where they exit the car ? 16MY Estoril Blue SVR.............
Sun Nov 10 2013 5:14pm |
The one on the drivers side should exit the bottom of the car with the fuel filler cap drains, the other side will be in the same place, I would just gently push a curtain wire down from the top first and then see if you can see water dripping down at the rear of the car.
Sun Nov 10 2013 5:20pm |
Thanks mate - much appreciated I will try that next 16MY Estoril Blue SVR.............
Sun Nov 10 2013 5:22pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
I hope this goes well for you and you decide to keep that sport |
Sun Nov 10 2013 7:38pm |
Glad it's down to the sun roofs guessed that might be the case.
Sun Nov 10 2013 8:16pm |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Hi Peachy, sorry you are having trouble mate, hope you get it sorted.
Sun Nov 10 2013 9:33pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Sounds like you have SAD Peachy. Withdrawals from washing maybe.
Sun Nov 10 2013 10:29pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I had this problem with my 07 once and never got to the bottom of it, but it has never happened again. There was a Technical Bulletin issued by Land Rover for the earlier models for an amendment of the A pillar if you can get hold of it..good luck.. Also no sunroof in mine to cause confusion.. |
Mon Nov 11 2013 9:22am |
Hi Peachy,
Mon Nov 11 2013 11:44am |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 |
Where did you get the black door handles peachy ? Cheers Bob |
Mon Nov 11 2013 12:53pm |
