Home > Technical > AFS Control Module location
robmeister1969
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
Could anyone tell me exactly where I can find this? My understanding is that it is towards the bottom of the drivers side A Pillar. I have removed this (from the inside) but can't see it. I wonder if I need to access it from under the wheel arch?
Post #399807 Fri Oct 25 2013 5:12pm
Paddi
Changes with L or R hand drive. On R/H drive vehicles it is on the passenger's side? 2008 MY Java Black TDV8 HSE
Post #399811 Fri Oct 25 2013 5:44pm
robmeister1969
Thanks Paddi. I did wonder if that was the case but couldn't see anything there.
Post #399843 Sat Oct 26 2013 8:14am
robmeister1969
This is a shot from behind the passenger side footwell. Really difficult to move these connectors, but I cannot see where the AFS Control Module is. Also have taken a good look at the drivers side footwell. Just checking to see if anyone can tell if I'm missing something obvious?
PS photo is posting upside down!
Post #400631 Thu Oct 31 2013 10:15am
Paddi
Looks as if it is behind the passenger dash end fascia panel: See the description of removal in my gallery:
http://www.rrsport.co.uk/gallery/albums/us...emoval.pdf
or better still perhaps can insert page as image!
Hmmm.... the gallery pdf is much easier to read!
Hope this helps 2008 MY Java Black TDV8 HSE
Post #400693 Thu Oct 31 2013 6:53pm
robmeister1969
Paddi - thanks for your further help.
Your PDF gave me the confidence to press on knowing that the AFS ECU must be there somewhere!
What a Censored getting the CJB out was. Having managed to get it out, I thought I would never be able to get it back in and connected and then when I did I had no power to my electric windows, door mirrors or key fob locking Big Cry
So I had to do it all again - thankfully a lot quicker the second time. I don't think one of the rear connectors had been plugged back in correctly Whistle
As a quick summary for anyone else who needs to do it:-
To remove the CJB:-
- remove kick panel and trim panel under glovebox (if you're able to remove the lower glove box - I wasn't - I think that would be a big help)
- unplug 3x connectors on front face of CJB - with finger and thumb press in retaining clips and then lift 'handle' which disengages plug
- unplug green connector at bottom of CJB
- there are 2x 10mm bolts at bottom of CJB (either side of green connector) which when removed allows for the CJB to be pulled towards you and manipulated downwards
- reach in behind CJB and there are two connectors* plugged in to the back of the CJB which are really awkward to get back in - there is a retaining clip which needs to be pushed forward to release the connector.
- once these are removed you should be able to manipulate the CJB out
- apply ointment and bandages to knuckles, fingers, elbows, etc. which will have been cut and grazed along the way Thumbs Up
Once the CJB was removed, I could see the AFS ECU. Even so it looked very difficult to get to and I ended up bending the retaining bracket to get it out.
I now need to find a replacement AFS ECU!
I note that the AFS ECU for Jaguar is identical in shape, has a similar part number and is about 10x cheaper i.e. £30 so I'm thinking about taking a punt on one of those - I used to have a Jaguar XKR but I don't recall the lights initialising in the same way that the RRS does, so maybe won't work?
Post #400828 Fri Nov 01 2013 7:22pm
Paddi
Rob,
Glad you managed it eventually - sounds a ghastly job Bow down
The instructions for glovebox removal would have been helpful but I can't find them! Perhaps someone else can help?
Hope you manage to find a working unit to get your lights working properly (assume that is the problem you are trying to fix). 2008 MY Java Black TDV8 HSE
Post #400907 Sat Nov 02 2013 7:42pm
