Home > In Car Electronics > How do you remove the limiter off Sound system |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
I believe there are software that increase the volume output of the Iphone, that should help a bit '08 RRS TDV8
Fri Oct 25 2013 7:21am |
This has been raised before. What you need is a means of connecting directly from the lightning connector of the iPhone 5 to the aux port. This way you will be getting a better lineout quality signal and not the feeble output from the iPhone's headphone socket.
Fri Oct 25 2013 12:53pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Would this work for an old I pod classic then? Where Would the USB plug go? |
Fri Oct 25 2013 6:41pm |
Yes and you won't need the adapter. The USB plugs into a cigarette lighter charger (£9 in Sainsburys)
Sat Oct 26 2013 9:49am |
