Home > General > fault codes
alan
United Kingdom 2008 Range Rover Sport TDV6 S Zermatt Silver
fault codes
hello all im new here and would appreciate any help you can offer me.i have fault code p0 23d-22, manifold absolute pressure turbochare boost sensor a correlation.an engine system fault notice also appears.my mechanics computer is not telling him any more so was wondering what the most likely causes are.its an 08 tdv6 71000miles,egr valves done recently.many thanks
Post #399343 Mon Oct 21 2013 7:21pm
Disco_Mikey
More than likely a split hose at the front of the engine, between the engine and intercooler. Failing that, a seized actuator rod Thumbs Up
Post #399389 Tue Oct 22 2013 5:44am
alan
Thanks il get that checked sounds relatively painless for once!cheers
Post #399412 Tue Oct 22 2013 9:11am
alan
It was actually one of the pipes or hoses not sure that went it to the new erg valve,it had come loose.all fixed now.hope this helps someone else.
Post #399511 Tue Oct 22 2013 7:29pm
