![]() | Home > Technical > Thinking of buying |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Welcome - use the search function on the top banner this will give you all the info you should need - there is a lot of good info regarding what to look for etc - |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Hi, engine? Like all cars, service history. Check all switches. Make sure it raises and lowers ok. Listen for air compressor noise. Loud and slow? Maybe on it's way out if it does. 96000 for year seems average. If this is your first rrs you will love it. |
Welcome to the site. |
greyheadgit Member Since: 21 Oct 2013 Location: Lincoln Posts: 13 ![]() ![]() |
What are the main differences between a SE and a HSE as it comes with a high spec |
The car is on Autotrader |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
So are lots of them. Hard to give you much advice other than search without a link to it. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
