![]() | Home > Technical > code P0231, any remedies please? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
P0231 - Fuel Pump Secondary Circuit Low
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
thanks. Wouldn't any of the above cause the engine management light on the dash to light up ? I'm assuming that if it doesn't, then the fault isn't critical or corrects itself |
I would imagine any of the possible causes listed above would cause a non-start issue.
No, it's always been there. I have had problems starting in the past, twice actually. Well, the car started but wouldn't accelerate when in gear. Lasted a few minutes then back to normal. So may be something intermittent? Since yesterday, no problems. Travelling 200 miles today - so that should 'test' it out |
It may be an underlying issue, just waiting to become a permanent fault...
