![]() | Home > Faults & Fixes > Transmission Fault |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
I wonder if the removal of the battery for 2 weeks has caused the transfer box control module to forget its calibration? You should probably get it looked at by a suitable garage in case it's something more involved though.
Obviously, this may have nothing to do with the error so it's probably best to speak to a garage first. The alternative is to make sure the battery is in good shape - a dying battery can throw up any number of odd error messages... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
franciscolalas Member Since: 27 Mar 2012 Location: Portugal Posts: 28 ![]() |
Thanks for the reply,
New transmission ECU and new actuator motor solved the problem.
Are you sure it was the transmission ECU that was changed and not the transfer box ECU? The transfer box ECU is in the engine bay behind the battery and can easily be drowned if the engine bay is washed because the water protection isn't very good. The transmission ECU is actually inside the gearbox so to change it requires draining the box, then the ECU change then refilling the box with £200+ worth of special ZF transmission fluid. 2008 MY Java Black TDV8 HSE
Yes, it was the transfer case ecu that was replaced. |
Well I'd have a frank discussion with your friend then. Looks as if he may have got the ECU wet when he washed the engine bay. The other parts probably didn't need to have been changed but franchised dealers do tend to change multiple parts first without going step by step. 2008 MY Java Black TDV8 HSE
They first changed the motor which they tested first and was faulty.
marinj Member Since: 02 Oct 2013 Location: Barcelona Posts: 1 ![]() ![]() ![]() |
Hi, I am sharing my experience, a few years later this post, in case it can help others. (05 RR Sport)
seelandi Member Since: 16 Aug 2015 Location: Germany Posts: 4 ![]() ![]() |
The described procedure from RRSTDV8 has fixed my RRSTDV6 (2005) completley!
