![]() | Home > General > towing capacity detatchable tow hitch |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
3.5 tonnes. The maximum nose weight is 150kg I think.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
http://www.towcar.info/advise_2.php?merk=L...;periode=0
The "85% rule" is a Caravan Club recommendation for single axle caravans rather than twin axle utility trailers isn't it? 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
For occasional towing, the QR one will be fine.
Not surprised D_M, the QR ball does have a tiny bit of play so I could see that continued movement in use would be quite damaging. If and when SWMBO gets her horse to the stage where we're taking it out on a regular basis in the trailer, I shall be having the multi height bar fitted. 2012 SDV6 - it's missing a couple of cylinders
It happens more often than you would think |
The 85% guide is a safety recommendation and if you are a novice worth considering for any trailer |
mark b Member Since: 29 Sep 2013 Location: stoke Posts: 17 ![]() ![]() ![]() |
i only tow this trailer maybe 10 times a yr |
Muddy, I'm not knocking your post or disagreeing with your basic position. |
I get that and never crossed my mind |
In Aust our RRS are rated to tow 3500kg with a max tow ball weight of 350kg. Our cars don't have any problem towing at these weights for extended periods but as the UK tow bar is considered inadequate for our needs LR Aust provides a different two part bar that is fitted into the standard fitting in the rear cross member.
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
If only the Mitch Hitch was allowed in the UK....we have some here in the UAE....best for towing, recovery points etc.....but the UK is wuss on such things. Ra-Ro Sport Super Dooper Charged.
