Home > Technical > Alarm wont stop after reconnecting alarm tdv6
r4_rick
Having a bit of a nightmare ! Disconnected battery to put new steering wheel on and i cant get the alram to stop sounding, tried the stuff in the handbook, car will start but alarm carries on blazing !
Have taken off battery put it on charge and will try again on sunday evening
Any ideas on the correct process ?
Rick
Post #396516 Sat Sep 28 2013 6:04pm
Paddi
Never had that problem but there is a sticker next to the battery with pictograms telling you to unlock then wait ?5minutes for car to go to sleep then remove battery. You could try doing a hard reset before connecting battery. Just means connecting the battery leads to each other for a minute or so (use jump lead or a long spanner) then connect battery. 2008 MY Java Black TDV8 HSE
Post #396517 Sat Sep 28 2013 6:23pm
r4_rick
Paddi, thanks for that, turned out to be a bit simpler....one of the horn buttons had got jammed down when i had put the air bag back in !!!
Post #396726 Mon Sep 30 2013 9:33pm
Paddi
Rolling with laughter Useful information for anyone changing their wheel tho' - something to be aware of. 2008 MY Java Black TDV8 HSE
Post #396742 Tue Oct 01 2013 8:26am
