Home > In Car Electronics > I Phone
hunter
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I Phone
Hi guys done a search but i can't get my phone to retain its pairing..it does pair but doesn't automatically connect the next time i turn on the ignition...i have to enter 2121 on my phone again...is this normal?
Post #396514 Sat Sep 28 2013 5:17pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Hi mate- yes it's normal.mines the same and it drives me mad. Apparently there's a little module in the boot that you can change for a newer version that will prevent you having to pair every time
Post #396532 Sat Sep 28 2013 9:15pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
No doesn't sound normal. Sounds like you need a new upgraded Bluetooth module.
Bodsy is the man to speak with. Thumbs Up
http://www.rrsport.co.uk/forum/member-bodsy.html 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #396535 Sat Sep 28 2013 11:27pm
PEACHY
As above ^^^^^^^ had mine changed by Bodsy Bow down with a few other upgrades - pairs every time even when Im not in the car ( sitting in living room Rolling with laughter ).
Thumbs Up 16MY Estoril Blue SVR.............
Post #396538 Sun Sep 29 2013 6:09am
hunter
Cheers guys, great info Thumbs Up
Post #396540 Sun Sep 29 2013 7:00am
flack
You need the Bluetooth updating it will then give you phone book on the radio and stop the pairing issues...
Flack Thumbs Up
Post #396547 Sun Sep 29 2013 8:50am
hunter
Where do i get an update? Is it soft wear or a module?
Post #396550 Sun Sep 29 2013 8:53am
flack
I can do it for you but I think Bodsy would be nearer to you so pm him it takes about 30 mins to do..
Flack Thumbs Up
Post #396551 Sun Sep 29 2013 8:55am
Bodsy
Site Sponsor
Hunter/blade boy,
I can sort out the BT modules for you no problem. As well as stopping the pairing problem, it also gives you the contacts from your phone that you can then select on the radio screen. (Well, up to 300ish contacts).
Can be done by post or if you want any of the other updates available, can be done in person Thumbs Up
Drop me a pm or email Thumbs Up
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #396561 Sun Sep 29 2013 12:08pm
hunter
PM sent Very Happy
Post #396570 Sun Sep 29 2013 3:49pm
Bodsy
Site Sponsor
Will be with you Tuesday. Thumbs Up Bodsys Brake Bible
See it HERE
Post #396571 Sun Sep 29 2013 4:08pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
I have a similar problem with my 2013 HSE Black which I would have thought was equipped with the latest bluetooth software. Is there a recent software change which fixes this? I keep blaming the Apple bluetooth software.
My connection is very hit and miss. Sometimes it's ok, other times I have to turn the bluetooth off on the phone and then back on to get it to connect. Phone book downloads ok.
Post #396671 Mon Sep 30 2013 5:28pm
Bodsy
Site Sponsor
Shouldn't have the same issue with the newer modules. There's no update available for the newer vehicles.
I'd try disconnecting the battery, shorting the positive cable to the earth (not on the battery!) the reconnect an try again. Bodsys Brake Bible
See it HERE
Post #396679 Mon Sep 30 2013 5:58pm
jimbg
Not sure about iphones, but with my Android phone, after you pair it requests permission to transfer the contacts.
If you do not tick the remember option then you have to repeat the process every time. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #396688 Mon Sep 30 2013 7:10pm
hunter
All sorted, thanks Bodsy...great service Very Happy
Post #396773 Tue Oct 01 2013 1:55pm
